Openbox: Switch languages using the keyboard and xxkb
Contents
Overview
The installation of the Openbox variant of Manjaro Linux does not provide an "Out Of The Box" Command Line or Graphical Tool for changing between multiple installed languages (Unlike some other heavyweight DEs. See GNOME, KDE, etc). One way of overcoming this pitfall is to manually edit some key System-Files and use a Third-Party Graphical Language-Keyboard Switcher.
This guide shows you how to achieve Language-Keyboard Switching using System-Files Editing and the Third-Party Tool XXKB.[1] The configuration shown here is the minimum possible in order to achieve the goal (More extensive configuration can be used).
This guide assumes the following:
- The Name of the user configuring the system is "Jimmy".
- The Languages that need to be switched are English (United Kingdom) and Greek (Polytonic).
- English (United Kingdom) is the default system language.
- The Key-Combination that will be used for the switching is Left Alt + Left Shift.
Install the prefered languages
Edit file /etc/locale.gen
sudo nano /etc/locale.gen
Uncomment only the lines for the required languages. In this case the lines
el_GR.UTF-8 UTF-8 en_GB.UTF-8 UTF-8
and save.
Regenerate locales for the changes to take effect
sudo locale-gen
Enable Console language switching
Edit file /etc/vconsole.conf
sudo nano /etc/vconsole.conf
Change the content to read
KEYMAP=uk KEYMAP_TOGGLE=gr
and save.
Enable X11 language switching
Edit file /etc/X11/xorg.conf.d/20-keyboard.conf
sudo nano /etc/X11/xorg.conf.d/20-keyboard.conf
In section "InputClass", after the line Identifier "system-keyboard", add the lines
Option "XkbLayout" "gb,gr(polytonic)" Option "XkbOptions" "grp:lalt_lshift_toggle,terminate:ctrl_alt_bksp"
and save.
!!! If you have used the MHWD utility to configure your graphics card, then there will be a file 90-mhwd.conf. For the changes you have made in file 20-keyboard.conf to work, you have to edit this file and comment out the line with the XkbOptions, in section InputClass, as below:
Section "InputClass" Identifier "Keyboard Defaults" MatchIsKeyboard "yes" #Option "XkbOptions" "terminate:ctrl_alt_bksp" EndSection
Install & configure graphical language switcher (xxkb)
Install program xxkb
sudo pacman -S xxkb
Create folder in /home/jimmy/.config that will hold the language flag images used by the xxkb switcher
sudo mkdir /home/jimmy/.config/xxkb
Go to any site providing free images of country flags and download the flag images for United Kingdom and Greece.
Resize the flag images you downloaded to 20x20 pixels and convert them to be of type xpm.
Rename the flag images to gb.xpm and gr.xpm for United Kingdom and Greece respectively.
Copy the flag images into the folder /home/jimmy/.config/xxkb that you have previously created.
Create configuration file for xxkb in user's home folder.
sudo nano /home/jimmy/.xxkbrc
Edit it to read
XXkb.image.path: /home/jimmy/.config/xxkb XXkb.group.base: 1 XXkb.group.alt: 2 XXkb.mainwindow.type: tray XXkb.mainwindow.enable: yes XXkb.mainwindow.appicon: yes XXkb.mainwindow.border.width: 1 XXkb.mainwindow.label.enable: no XXkb.mainwindow.border.color: white XXkb.mainwindow.geometry: 20x20+0+0 XXkb.mainwindow.image.1: gb.xpm XXkb.mainwindow.image.2: gr.xpm XXkb.mainwindow.image.3: XXkb.mainwindow.image.4: XXkb.mainwindow._delete: no XXkb.button.enable: no XXkb.controls.focusout: no XXkb.controls.two_state: no XXkb.controls.add_when_start: yes XXkb.controls.add_when_create: yes XXkb.controls.add_when_change: no
and save.
Make xxkb autostart when openbox starts
Edit openbox's autostart configuration file
sudo nano /home/jimmy/.config/openbox/autostart
In section ##Startup, after the last line, add the line
(sleep 1s && xxkb) &
and save.
Reboot the operating system
sudo reboot
