Setting the Default Sound Device
From Manjaro Linux
Jump to: navigation, search
This worked for me
Remember: ALSA support is part of the kernel.
Pulseaudio is an ALSA wrapper that can do some things
that ALSA can't do by itself. Most of us don't need
those things. This solution works for both ALSA & Pulse.
Though "straight" ALSA is simpler, & therefore more
likely to work.
If your system keeps on using the wrong device (HDMI instead of PCH or vica versa, or some other problem), then do the following so you can identify the devices number & then instruct your system to use that number/device:
  • Run alsamixer - if you have it installed, just enter:
 alsamixer
at the terminal prompt.
  • In alsamixer hit the F6 function key, then you'll see the devices listed in a little box, with their numbers in front of them.
OR
  • Enter the following into a terminal:
 cat /proc/asound/cards
  • Choose the number of the sound device that you want to use.
  • Then using your text editor of choice, put the following into /etc/asound.conf (You will most likely have to create /etc/asound.conf ).
  defaults.pcm.card 1
  defaults.ctl.card 1
Change the number from 1 to 0 , 2 or whatever?
  • Save the file & play a movie or listen to a tune.
I can imagine that if you had need to change between two sound devices from time to time, you could write a simple script that quickly swapped from one /etc/asound.conf file to another. All it would have to do is change/swap the file extensions from asound.conf.bak to asound.conf & visa versa when desired. ;)
The core information in this page came from the ALSA Project: [1]
This worked for someone else using Pulse
https://forum.manjaro.org/t/pulseaudio-keeps-changing-my-default-output-device/36562
Support
Following is a link to this page's forum counterpart where you can post any related feedback: [2]
