Networking
From Manjaro Linux
Jump to: navigation, search
Overview
Networking on Manjaro generally works out of the box without and special user intervention. This article presents some specialized circumstances which some users may encounter and provides advice on how to overcome them.
Manually Setting DNS Servers
Usually, your DNS servers will be provided by your ISP automatically through DHCP. However, sometimes it nesecary to use different DNS servers than the ones provided by your ISP. In this situation you may find that your DNS or other non-standard nameserver addresses will get reset on reboot as /etc/resolv.conf can be overwritten by NetworkManager or during the boot process. Here we will look at some techniques to preserve your settings.
NetworkManager
If you are using NetworkManager, this is one solution to the problem. The NetworkManager's config drop folder is placed in /etc/NetworkManager/confg.d. In this folder you can place snippets which controls how NetworkManager works. The files should be named with a number and a description of its purpose and always end with .conf. The files are then applied in numerical order from the lowest to the highest. A configuration in a file with a higher number will override what could have been configured in a lower numbered file.
Use resolvconf
To have the resolvconf script handle the resolv.conf file for NetworkManager. Create a configuration file in NetworkManager's config drop folder
/etc/NetworkManager/conf.d/20-rc-manager.conf
Save the file with this content
[main]
rc-manager=resolvconf
To effectively make DNS handling a manual task create a file named
/etc/NetworkManager/conf.d/99-dont-touch-my-dns.conf
[main]
dns=none
/etc/resolvconf.conf
The resolvconf.conf file is a shell script that is sourced by resolvconf, meaning that resolvconf.conf must contain valid shell commands. Take a look at its man page for more details and commands. The file is located at /etc/resolvconf.conf and will require root privelege to edit. For more information on how to edit a configuration file owned by root, please review this article.
As an example, we will prepend OpenDNS nameservers to the top of our resolvconf file whenever called. We can achieve this by adding the following lines to the bottom of resolvconf.conf.
# OpenDNS servers
name_servers="208.67.222.222 208.67.220.220"
After making any changes simply update and apply your settings with the following command
sudo resolvconf -u
dhcpcd and resolv.conf.head/tail
note: Most Manjaro installs will not be using dhcpd by default
An alternative solution if you are using dhcpd is to input our settings to the /etc/resolv.conf.head file. If this file does not exist then create it. The contents of /etc/resolv.conf.head get sent to the top of /etc/resolv.conf during the boot process.
Following our previous example, if we want to use the OpenDNS servers with this method, we could place the following in the file:
# OpenDNS servers
nameserver 208.67.222.222
nameserver 208.67.220.220
Setting Static IP Address
Using a GUI Tool
Most editions of Manjaro come with some type a GUI tool or applet to manage NetworkManager. This is the easiest way to set a static IP. Simply go into the tool, usually in the system tray or menu, and input the required parameters for your network.
Using systemd
If you don't want to use NetworkManager the next easiest thing is to configure a static IP in systemd.
First, make sure you aren't running NetworkManager
sudo systemctl disable --now NetworkManager.service
Next you will need to find the name of your network device. To locate the name, use the command ip a as seen here:
ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: ens33: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
    link/ether 00:0c:29:02:55:c4 brd ff:ff:ff:ff:ff:ff
    inet 172.16.197.200/24 brd 172.16.197.255 scope global dynamic noprefixroute ens33
       valid_lft 1725sec preferred_lft 1725sec
    inet6 fe80::7116:2769:dac:6314/64 scope link noprefixroute
lo is the loopback device which can be ignored for the purposes of this article. The device we need here is identified above as ens33. We will need this name in the next step.
Now create or edit a file to hold the network configuration at /etc/systemd/network/devicename.network. Using the example above, the file would be called /etc/systemd/network/ens33.network. This file will need to be created/edited as root. For more information on how to do that please review this article. An example of the contents of the file would look like this:
[Match]
Name=enp0s3
[Network]
Address=192.168.1.101/24
Gateway=192.168.1.1
DNS=208.67.222.222
DNS=208.67.220.220
All that remains is to start and enable the service using:
sudo systemctl enable --now systemd-networkd.service
Using dhcpcd Instead of NetworkManager
NetworkManager is the default solution for networking on most Mnajaro editions. If you would prefer to use dhcpcd, that is also supported.
First, ensure NetworkManager is disabled and not running
Next, start and enable the dhcpcd service
sudo systemctl start --now dhcpcd.service
See Also
