Mantenimiento del Sistema
Descripción
Este articulo contiene algunos consejos y buenas practicas para mantener tu sistema en optimas condiciones.
Cache de /home
El directorio oculto de .cache es usando por varias partes de tu sistema. Esto incluye descargas, miniaturas, recursos de escritorio, y mucho mas.
Mientras esto es generalmente seguro eliminar todo en el directorio /.cache, tal vez sea mas recomendable verificar el contenido y de forma selectiva eliminar los archivos en el.
Para generar una lista aleatoria de los contenidos y tamaños:
To automatically purge all .cache files that have not been accessed in 100 days:
Journal and Logs
Log files & the systemd journal do the same thing in different ways. They keep a record of everything that happens on your system.
For more information and tips on automated maintenance please see the dedicated page Limit the size of .log files & the journal
Systemd Journal
The journal keeps logs of system activity. This can be important for troubleshooting, but sometimes the log size can grow rather large.
To report the current size:
To remove all but the most recent entries by size or time:
To set a maximum size for the journal you can uncomment and edit the following line in /etc/systemd/journald.conf:
SystemMaxUse=50M
System logs at /var/log/*
While most things use the newer systemd journal (journalctl), there is still some software that uses the older /var/log/ directory.
For more information and some tips on maintaining it, please see the relevant section of this page.
Packages and Updates
Keeping your System Updated
On a rolling release distribution it is essential to keep your system fully updated. Manjaro provides a few ways to keep your system updated.
- You can use the GUI tool Pamac directly or via the update notifier
- You can use the GUI tool Octopi directly or via the update notifier
- You can use the Pamac CLI
- You can use the Pacman CLI
Avoiding Partial Updates
It is of critical importance to ensure you don't end up in a state where your system is partially upgraded.
It is not uncommon for systems in partially updated state to end up in a critical failure state.
Here are some rules to help you avoid this undesired situation.
- Don’t update the local package database (metadata) without also updating the system
- You may install a single package using
pacman -S <pkgname>but this may yield a 404 error if your metadata is not current - Don't use
pacman -Sy,pacman -Syy,pacman -Syuwas this will update the metadata but not sync the packages to your system - Always sync metadata and packages together
pacman -Syu - Don't add packages to pacman's or pamac's ignore list
- If you just want to check to see what updates are available use the command
checkupdates. This provides a safe way to check for upgrades to installed packages without pulling metadata at the same time - When switching branches or switching mirrors always sync your systems metadata and packages using
pamac updateorpacman -Syu - If you get 404 in connection with a branch switch you may force sync metadata by doubling the y argument
pacman -Syyu
Removing Orphans
As packages are added, built and removed it is not uncommon to have unneeded dependencies, also called orphans, building up over time. While orphans are not harmful, they take up space on the disk and consume network bandwidth as they are continually updated. Luckily, there are a couple of easy ways to view and remove orphans.
To use pamac follow this guide.
To use pacman follow this guide.
Package Cache
By default both pamac and pacman keep a cache of downloaded packages on the system. This can be helpful if you need to copy or downgrade a package.
But the cache can grow to include dozens of each package resulting in gigabytes of space.
Pacnew and Pacsave files
A .pacnew file may be created during a package upgrade to avoid overwriting a file which already exists. A .pacsave file may be created during a package removal, or by a package installation of a package that was removed. These files require manual intervention from the user and it is good practice to handle them regularly. The program pacdiff can help manage this process. For example, here is what it looks like when the /etc/default/grub grub file has changed:
DIFFPROG=meld pacdiff -s ==> pacnew file found for /etc/default/grub :: (V)iew, (S)kip, (R)emove pacnew, (O)verwrite with pacnew, (Q)uit: [v/s/r/o/q]
Vshows the differences between the two filesSskips to the next change and allows you to deal with it later or manuallyRkeeps your existing file and delete the new fileOoverwrites the existing file with the new fileQquits the process without making further changes
Unfortunately, there is no perfect road map for how to deal with these files. If you keep the original config file, and the syntax has changed, the program may stop working or fail to use the existing config. If you remove the original file and use the new file without any changes, all your configuration settings can be overwritten. Sometimes, you need to combine pieces from the new and old files to make everything to work. In these situations it is better to integrate the files manually.
For more detailed information, please see review the Arch Wiki linked below.
Keeping the system time accurate may seem unimportant but certain network related services may malfunction if the time is out of sync.
The easiest way to ensure the time is being properly synchronized is the GUI tool included in Manjaro Settings Manager which is pictured to the left. Simply check the box next to "Set time and date automatically".
An alternative is to use systemd via the systemd-timesyncd service. This can be easily enabled with one of these commands:
See Also
- The Arch Wiki guide on System Maintenance
- The Arch Wiki guide on Pacnew and Pacsave files
- The Pacman wiki article
- The Pamac wiki article
